Boris FX very basic getting started needed..
COW Forums : Boris FX
David Hicks
on Feb 9, 2017 at 8:18:22 pm
Hi
I'm a Newbie to CC and to Boris FX. I use Lightworks NLE and have recently purchased Boris FX & Grafitti. Ordinarily, Boris runs under Lightworks natively but only under Win 64-Bit, but a hiccup from LWKS Support before purchase informed me that it 'would' run under Win 32-Bit.
So, I have to run Boris as standalone until I upgrade to 64-Bit. When running natively if you want to add say a transition the host nicely loads the 2 clips i.e. Incoming Video 1 & Outgoing Video 2 into the Boris GUI at launch. Loading them manually correctly in stand-alone mode seems to be illuding me.
So can anybody point me toward a very basic getting started doc or video tutorial that shows how to load the the clips, I can go from there.
Many thanks,
Regards, David
peter mcauley
Re: Boris FX very basic getting started needed..
on Feb 10, 2017 at 6:22:07 pm
Hi David,
Please contact me offline at (peterm@borisfx.com) and I'll work with you directly on this.
Peter.
