BCC 10 mocha in Premiere Pro
COW Forums : Boris FX
dan luke
on Sep 21, 2016 at 3:24:36 pm
When I try to add a boris effect to a clip that has another effect with a mocha mask, I get a shadow of the mask offset on the clip. What am i doing wrong?
Jon Kozenko
Re: BCC 10 mocha in Premiere Pro
on Sep 22, 2016 at 3:52:35 pm
Hello Dan,
Do you think you can show me sample screengrabs, showing before and after, of this situation? You can send them to support@borisfx.com. Also, in your workflow of applying a new BCC filter, I presume this happens immediately when you apply the second BCC filter, rather than later, such as after enabling the PixelChooser? Lastly, what host and OS are you running?
Thanks.
Jon
dan luke
on Sep 22, 2016 at 11:31:27 pm
10.10.5 mac os host is the avid and premiere version. I apply an effect, draw a mask and then as soon as i layer another effect on i get the offset without enabling pixel chooser on the second effect. I'll send a pic.
-dan
dan luke
on Sep 22, 2016 at 11:36:50 pm
ok so now it's not doing it. Maybe it just needed a reboot which i have done several times in the last 48 hours because of other PP2015.4 bugs.
