cc 10 title studio plugin for premiere pro acts goofy
COW Forums : Boris FX
dan luke
on May 29, 2016 at 9:08:02 pm
Using templates for lower thirds. Everything lines up in the Title studio GUI but the effect is not lined up in Premiere. It's wrong whether or not i have the [use transformations] check box selected in the PP effects panel.
Jon Kozenko
Re: cc 10 title studio plugin for premiere pro acts goofy
on May 31, 2016 at 5:21:24 pm
Hello Dan,
I saw that you also created a case with Support and replied there moments ago. Primarily, I was wondering if you could relay me some screen-shots of how they look after you go back into Premiere Pro, preferably with the templates identified. If you are able to relay those to me in Support I can take a look with a few people here and isolate what might be causing the problem.
Thanks.
Jon
