Extra frame being added
COW Forums : Boris FX
Andrew Beavis
on Mar 4, 2016 at 1:42:03 pm
HI, I am using Corel Videostudio X9.
When I upload a 10 second video to Boris it creates an extra frame for some reason.
i.e The video then lasts a duration of 10.01
This is messing with some of the effects as I need the video to loop.
It wouldn't be so bad but when I add a track media clip to the project it will add it as the correct 10 seconds.
Hope that made sense.
Any help would be appreciated.
Cheers
Jon Kozenko
Re: Extra frame being added
on Mar 8, 2016 at 11:11:56 pm
Hello Andrew,
In Graffiti, you will see a frame at the very end that would not exist, but this should only be a preview frame, and shouldn't appear once you Apply back to your Host. Have you noticed the problem after Applying back and performing the clip as a loop? One thing you can try would be to move the final Keyframe(s) back one frame to off-set this extra frame.
Hope this helps.
Thanks.
