Boris IMPORTING STILLS problem
COW Forums : Boris FX
Steve Mott
on Nov 18, 2015 at 10:29:19 pm
When I import a photo file(square pixels) using either BorisFX red engine or AvidFX, Boris imports the image smaller than it's native size. In the Media Info window: Image size - Boris displays the native size and also the imported size. I created new compositions and imported different images - didn't work. I closed out and restarted the program - didn't work. Restarted computer - didn't work. Finally, shut down and restarted...this also didn't work either. Anybody have any idea why?
Jon Kozenko
Re: Boris IMPORTING STILLS problem
on Nov 19, 2015 at 5:53:13 pm
Hello Steve,
When you Import, are you doing this by using the File > Import command, or are you using the 'Add Image Media' button in the RED timeline? If you're going through the File > Import approach, does using the Add Image Media approach cause the same problem? Is this happening in the stand-alone version of the RED or Avid FX engines, or just when loaded from Avid (or any other host)? Lastly, is it both the X and Y pixels that are adjusting, or just one of these two dimensions?
Jon
Steve Mott
on Nov 30, 2015 at 3:50:05 pm
Ended up being the preview quality and preview resolution I was working in. While working in lo-res, the import size reflects this change.
