Boris red 5.5.3 - Avid problem - preview is black halfway
COW Forums : Boris FX
Eric Simoneau
on Jan 23, 2015 at 7:25:49 pm
Hi!
First post on here.
so my problem with Boris Red is that, when i apply the Boris RED for Avid filter on the timeline and i do my sfx. when i apply and step out of Boris, Avid shows me the FX preview, but halfway into the clip, the preview turns black.
So lets say i have a 30frame fade in, 180frame of scale up and various FX and a 30frame fade out at the end, Avid will show me the first 90frames of the FX then go black for the remaining 90frames.
When i render, i can see the whole comp.
Our company had AvidFX a while back and this wasnt happening, now we got Boris Red which is basicaly the same thing and were getting this problem.
Anyone ever had this issue?
thanks!
Jon Kozenko
Re: Boris red 5.5.3 - Avid problem - preview is black halfway
on Feb 13, 2015 at 11:16:32 pm
Eric,
This isn't a known issue, but since you're upgrading from AvidFX to RED, I would recommend deleting the preferences for both. If you're on PC, the files would be located here -
C:\Users\[CURRENT USER]\AppData\Local\BorisFX
If you're on a Mac, they would be located here -
Macintosh HD :: Users :: [Current User] :: Library :: Preferences
If this does not help, do you think you can reproduce this with a test project using some still images (just as test files small enough to send via email), and then forward this test project to support@borisfx.com?
Jon
