RED 5.5 default window
COW Forums : Boris FX
Kuhnen Brown
on Dec 23, 2014 at 1:38:48 am
Whether I boot up the stand alone RED, or drop the RED filter onto a clip on the Premiere Pro timeline, RED always opens with the Library Browser window active. I would like to have RED open with the Composite window open/active. Window/Workspace is set to Standard. I have a custom workspace with the Library Browser closed, yet the Library Browner still opens on boot up. Is there a preference file I can trash?
Kuhnen
RED 5.5.3
Host: Premiere Pro CC 2014
OS X 10.9.5
Jon Kozenko
Re: RED 5.5 default window
on Dec 23, 2014 at 4:26:02 pm
Kuhnen,
On OSX 10.9.5, there are actually two preferences files you are likely to find. The first one would simply be the 'Boris RED 5 Preferences', the other would be named "com.borisfx.app.Boris RED.plist". With RED (and any NLE's you have installed) closed, delete these two files. You can find them here -
Macintosh HD :: Users :: [ Current User/Home ] :: Library** :: Preferences
** - Note that this Library folder is hidden by default on OSX 10.9 - to access it, you would either need to use the Go menu in the Finder, or enable view of hidden objects.
Jon
Kuhnen Brown
on Dec 23, 2014 at 9:06:03 pm
Thanks Jon. That works!
Kuhnen Brown
InterMountain Digital
Oregon
Bart Molen
on Mar 21, 2015 at 9:48:50 am
Can this be done with Graffiti, I cant find the files?
http://www.gripps.net/
http://www.youtube.com/user/gripps2211?feature=mhee
