Boris Noise Reduction
COW Forums : Boris FX
Klaus Boehmer
on Oct 23, 2014 at 6:07:34 am
Hi there and good morning from Germany!
I have recently been fiddling around with the Boris Noise Reduction FX but no matter which preset I used, I could not see any difference between the input and the output so any help would be appreciated.
[IMG]http://i57.tinypic.com/kb7s4g.png[/IMG]
here's a link to a sample picture
thanks
Jon Kozenko
Re: Boris Noise Reduction
on Oct 23, 2014 at 1:46:16 pm
Hello Klaus,
Two quick questions. If you were to manually ramp up all of the settings to maximum, does this change the image at all? Or is it still identical? Second, what Host application are you using and which exact version of BCC?
Jon
Klaus Boehmer
on Oct 23, 2014 at 1:49:21 pm
I am working with Sony Vegas Pro 12 and BCC 7.0.4
if I pull all the sliders to the max I do see a change in the output picture but not necessarily a noise reduction, rather a blurring effect
