Motion Tracking problem with Bcc
COW Forums : Boris FX
Luke Passos
on Sep 23, 2014 at 2:04:23 am
Hey guys, I have a problem and need to fix with bcc 8 i have bought.
When i use the match move compositing mode, select a region for the track on the fly and hit "build dynamic ram preview" Sony Vegas only tracks very few frames now and it is becoming really annoying on how i have to deal with this, keep having to go back and track everything again, even when i select the whole video, it tracks like 5 frames and then says to go back to last tracked frame. And guess what? I have to go back to the last tracked frame and keep doing this like 2000 times.
PLEASE TELL ME HOW TO FIX THIS IF YOU KNOW
Also, is there any way to motion track a 3d space in Sony Vegas only, like 3d camera track (No AE or anything)? Is there a sony vegas plugin that can do that or any way to import a 3d tracker data into Sony Vegas?
Thanks for reading, please reply as soon as possible.
James Macon
Re: Motion Tracking problem with Bcc
on Sep 23, 2014 at 7:10:07 pm
Luke-
You might try setting your look ahead frames up a few notches or even having the filter render in a lower quality. See if that helps.
James
Luke Passos
on Sep 26, 2014 at 3:24:19 pm
Thanks man, will try the low render quality. What did you mean by: "setting your look ahead frames up a few notches" ?
James Macon
on Sep 29, 2014 at 8:11:49 pm
There is a parameter called Look Ahead Frames that sets a range of frames to cache in memory, allowing you to scrub through the timeline within the Look Ahead range to preview the track.
