Boris Continuum 8.3 and Premier Pro CC 2014 Export problems...
COW Forums : Boris FX
Gerry Cast
on Jul 27, 2014 at 3:51:24 am
I've never had problems with Premier Pro CC, but upon export from Premier Pro CC 2014 and using the Adobe Media Encoder CC 2014, the export hangs and fails halfway through if it's anything longer than two minutes in length. I only use the Color Correction effect and again, never had problems with Premier Pro CC.
Anyone else experience this?
Boris Tech Support told me to try the trial of Continuum 9, I did and same problem (and if I understand correctly, we're talking about a $300, upgrade to 9, right?)
I have a clean, fast Win 7 machine, with 16 gigs of memory and no other problems.
Very disappointed and will probably go back to Premier Pro CC.
