Boris FX 10 - Lens Flare issue
COW Forums : Boris FX
James Hernandez
on Jul 21, 2014 at 2:22:30 am
This might be an overly-simple problem, but...
I have an 11 second animation, it's a 3D animation rendered in Cinema 4D, so it's just a flat video now.
At about 7 seconds, I would like a lens flare to come on, and then brighten up before fading out.
PROBLEM: The lens flare just shows the ENTIRE 11 seconds. How do I keep the effect off until the 7 second mark?
I actually have this problem in a few of the programs I use. :)
Thanks for any help!
James Macon
Re: Boris FX 10 - Lens Flare issue
on Jul 25, 2014 at 8:48:48 pm
Hi James-
Try key framing the mix with original parameter to fade the flare in when you want. That should accomplish what you're looking for.
James
