installation problem with boris fx
COW Forums : Boris FX
Sid Olomi
on Jul 11, 2014 at 9:07:24 am
hello guys
i am using ssd as my C drive for fast booting but i install all my programs in a diff hard drive so AE an Pr pro is on diff drive when i try to install boris although it says completed but i can see effects in AE there is no way to let installer know where the AE is installed same with Red giant plugins same problem any idea which will help me with this problem thanks
Jon Kozenko
Re: installation problem with boris fx
on Jul 11, 2014 at 10:04:16 pm
Sid,
If your Adobe were installed on your C drive, there would be a folder, representing your Adobe CS version, in this location -
C:\Program Files\Adobe\Common\Plug-ins
Inside this folder (called '7.0' if you're using Adobe CC), there would be a MediaCore folder. Here is where the plugs for AE and Premiere Pro would install into.
If your Adobe is on your D drive, there might be one of these folders in the same location (except D:\ instead of C:\) - if so, you can try installing our plugs into there.
As for the option to select the install path, our products should have this ability in the 'Custom' install option.
Jon
