Premiere Pro CC 2014 and Boris RED 5.5 (Mac)
COW Forums : Boris FX
Kuhnen Brown
on Jun 22, 2014 at 12:36:48 am
After installing the new Adobe CC 2014 apps, and installing the latest Boris RED 5.5 update for Mac, I am not seeing Boris RED 5.5 in the Premiere Pro CC 2014 effects tab. The standalone is present and accounted for as version 5.5. But no sign of RED inside Premiere. Any advice?
Kuhnen.
Mavericks 10.9.3
Boris RED 5.5
BCC AE 9
Adobe CC 2014
Kuhnen Brown
Re: Premiere Pro CC 2014 and Boris RED 5.5 (Mac)
on Jun 22, 2014 at 6:12:41 am
Update to my post with additional info. I have two instances of Adobe Premiere Pro on my computer: they are the new CC 2014, and the previous CC from 2013. Adobe recommends retaining both the old and new versions. When I installed the RED 5.5 update, it attached itself to the old Premiere Pro from 2013, but did NOT get attached to the new Premiere Pro CC 2014. Once again, can you help me out here.
Kuhnen.
Kuhnen Brown
InterMountain Digital
Oregon
Boris Yamnitsky
on Jun 22, 2014 at 9:59:31 am
A small change in the installation procedure is necessary for Adobe CC 2014. We are planning to post an updated installer shortly. If you need to use RED right away, please contact our support on Monday. Very sorry for inconvenience. 888-77-BORIS
Boris Yamnitsky
BorisFX
Mike Escola
on Jun 22, 2014 at 12:00:32 pm
For the initial Adobe CC release, the MacOS Boris RED plugins were installed into:
/Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Plug-Ins/Common
The Boris RED plugins can be copied from here.
For CC 2014, they are installed into:
/Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Plug-Ins/Common
If you select the Adobe Premiere Pro CC 2014.app application and control click it, then choose Show Package Contents, you'll be able to open the folder above and copy the plugins into it.
-Mike
Mike Escola
on Jun 22, 2014 at 8:37:39 pm
The Mac Boris RED installer is updated with the CC 2014 option now.
Kuhnen Brown
on Jun 23, 2014 at 5:46:00 am
Thank you Boris, and thank you Mike.
Kuhnen
Kuhnen Brown
Oregon
Christopher Gomersall
on Jun 26, 2014 at 3:43:34 pm
Is BCC Complete for mac OSX for the CC 2014 Adobe apps deemed compatible?
Kind regards,
Chris Gomersall
http://www.vimeo.com/channels/texasvideopro
http://www.youtube.com/upstairsmedia
Kuhnen Brown
on Jun 27, 2014 at 9:26:27 pm
I use BCC9 on my Mac in both Premiere (2014) and AE (2014. Very compatible. Having a NVidia CUDA card is a benefit for some of the effects.
Kuhnen.
Kuhnen Brown
Oregon
amir pahlevani
Re: Premiere Pro CC 2014 and Boris RED 5.5.3 64 Bit for windows
on Oct 20, 2014 at 11:41:57 am
After installing the new Adobe CC 2014 apps, and installing the Boris RED 5.5.3 64 Bit for windows, I am not seeing Boris RED 5.5.3 in the Premiere Pro CC 2014 effects tab. How can I fix this problem? How can I get the updated installer as you mentioned on your post? Thanx
