Obscuration with older Lens Flare?
COW Forums : Boris FX
Jaeson Koszarsky
on Jan 30, 2014 at 9:50:06 pm
I watched this tutorial which uses BCC8 Lens Flare 3D:
http://www.borisfx.com/videos/BCCAE/Ultra-Realistic-Animations.php
I'm using Media100 Suite 2.1.5 with RED 5.1.5.
Can I achieve the same obscuration effect demonstrated in the tutorial by using the older Lens Flare Adv filter?
Jaeson
Jon Kozenko
Re: Obscuration with older Lens Flare?
on Jan 31, 2014 at 6:03:02 pm
Jaeson,
I compared the Lens Flare Adv effect and the Lens Flare 3D effect and found that this obscuration element is actually part of the Lens Flare 3D effect itself (rather than an After Effects function that Lens Flare 3D can utilize). As such, there is no direct way of creating such a direct obscuration with the Lens Flare Adv. In addition, the Lens Flare Adv does not have a Pixel Chooser tab, so this might be entirely manual in RED.
Thanks.
Jon
