Pan and Zoom for 3 points animation.
COW Forums : Boris FX
nicolas remond
on Jul 12, 2013 at 1:11:26 am
Hello,
I love Pan and zoom filter, it is extremely intuituive, fast, and produces flawless quality. I am using "AB automation" most of the time, and with the semi automatic and full control modes I have experienced some frustrations. In particular, I cannot manage to make a good smooth and regular animation with 3 stops: travelling from point A to point B, then from point B to point C. Is there a setting than could facilitate such 3 points animation?
Thanks in advance.
Nicoremo
James Macon
Re: Pan and Zoom for 3 points animation.
on Jul 12, 2013 at 5:59:56 pm
Hi Nicoremo-
If you change the speed of the animation to accelerate mode or change the interpolation to a curved mode you might get the results your looking for.
-James
nicolas remond
on Jul 13, 2013 at 4:14:33 am
Hello James,
I will try that, thanks!
Nicoremo
Michael McCune
on Aug 29, 2013 at 2:19:31 am
Nicolas; Can you bring up the graph mode in FX?
Douglas - Gaijin-Eyes - has a wonderful tutorial on the graph capabilities of FX. It is #16.07.
There is a huge benefit in *seeing* the FX transformations, as the different interpolation modes yield sometimes surprising or unexpected results.
It is all mathematical, of course, so the program is not making mistakes, but unexpected jerkiness I have found is easily fixed when one can see the curves and make changes directly in the graph mode.
Hope this helps.
Mike
