Boris Lighting Effect
COW Forums : Boris FX
Steve Bartley
on Feb 2, 2013 at 8:55:14 pm
Is it possible to add a lighting effect to bcc 3d object. I was trying to create something like the intro in Legendary Pictures. You can see it here
I'm using final cut and apple motion.
Any help would be greatly appreciated.
peter mcauley
Re: Boris Lighting Effect
on Feb 11, 2013 at 3:44:47 pm
You can do this a couple of ways (assuming that you're using FCP 7) ... either use Boris RED and composite everything in the RED UI (generate the 3D title graphic and use BCC Rays Puffy for the volumetric light rays) or you can stack BCC filters in the FCP UI ... BCC 3D Objects and BCC Rays Puffy.
I hope this helps.
Peter.
