Adding fog to the hand-held shot with motion tracker
COW Forums : Boris FX
Michal Bronec
on Jan 26, 2013 at 10:44:03 pm
I'm using Sony Vegas 11 with Boris Continuum 7. I need to add a smoke/fog to the video. I have pre-keyed fog from VideoCopilot or I can use Boris clouds effect too (both look good to me). The problem is that my video was shot by handheld camera. So I need to use motion tracking, so that the fog look like it belongs there to the shaky shot. How do I do it? I know some Boris plugins has motion tracker option, but not all (not clouds plugin).
peter mcauley
Re: Adding fog to the hand-held shot with motion tracker
on Jan 28, 2013 at 2:46:09 pm
I'd suggest using the L:end Flare 3D ... this filter includes both a motion tracker and a fog generator. You can disable all of the options except for the fog and use the motion tracker to lock the fog to the shaky motion of the scene.
Hope this helps,
Peter.
Michal Bronec
on Feb 1, 2013 at 12:23:21 am
Thanks, I will give it a try.
