2 point tracking in "BCC Corner pin" + Vegas Pro 12
COW Forums : Boris FX
David Shimamoto
on Nov 3, 2012 at 12:39:06 am
I have a question regarding usage of "BCC Corner Pin" with Vegas Pro 12.
Is it possible to use only two corners, instead of the standard four to define the overlaying area?
The background image I need to track involves rotation and zoom, however no change in the aspect ratio of the area to be covered.
Therefore, I actually need only two points to use as reference.
On the other hand, the background image does not have more than two good reference points I can track neatly.
Thank you in advance.
