BCC8 sony vegas pro 12 Problem
COW Forums : Boris FX
Matthew Funicello
on Oct 23, 2012 at 1:13:06 am
Hello Everyone Im having a issue for sony vegas pro 12 on installing
Bcc8 for Sony veags pro 12 So I installed the BCC8 and put in serial number and everything but when I load up sony vegas pro 12 Its not in my effects. Now I open up sony vegas pro 11 And the bcc effects are in their. Also I have went on the Uninstallation process and it says repair I dont know why but when I try to repair it says
Windows Installer
The feature you are trying to use is on a network OK
resource that is unavailable. CANCEL
Click OK to try agian, or enter an alternate path to a folder
containing the installlation package 'BCC 8 OFX 32Bit.msi'
in the box below
Use source:
C:UsersmattappDataLocaltemp_is3375 Browse...
If I hit ok this pops up
The path
'C"UsersmattAppDataLocal]Temp_is3375BCC 8 OFX
32Bit.msi' cannot be found. Verify that you have acces to this location and try agian, or try to find the installation package 'BCC 8 OFX32Bit.
Please help me out on this problem I used BCC7 on sony vegas pro 11 and now that I have 12 I would like to continue using it,
Thanks ,Sincerely Matt
Matthew Funicello
Re: BCC8 sony vegas pro 12 Problem
on Oct 23, 2012 at 2:04:30 am
Nvm I have had this problem fixed thanks any way
© 2018 All Rights Reserved
