Render in Vegas 11 crashes when applying glitter to extruded EPS
COW Forums : Boris FX
Chris Marquart
on Oct 15, 2012 at 6:51:24 am
I can consistently crash my Vegas 11 when the Glitter FX is added to an extruded EPS file. Here is the error
Problem Description
Application Name: Vegas Pro
Application Version: Version 11.0 (Build 701) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:Program FilesCommon FilesOFXPluginsBCC8_3DObjects.ofx.bundleContentsWin64BCC_3DObjects.ofx
Fault Address: 0x000007FEE9D9CB22
Fault Offset: 0x00000000003DCB22
Fault Process Details
Process Path: C:Program FilesSonyVegas Pro 11.0vegas110.exe
Process Version: Version 11.0 (Build 701) 64-bit
Process Description: Vegas Pro
Process Image Date: 2012-09-24 (Mon Sep 24) 22:55:36
Can I use both at the same time? I'd like to, it looks good for this project.
Thanks for any response
Chris
peter mcauley
Re: Render in Vegas 11 crashes when applying glitter to extruded EPS
on Oct 15, 2012 at 1:45:06 pm
Hi Chris,
Both the Extruded EPS filter and the Glitter filter are OpenGL effects. You should be able to stack multiple OGL effects without encountering an error - I wonder if your system is equipped with a video card that can process the OGL effects though. Have you cross checked your system config with the supported video card configurations listed on our web site? You can check that here:
http://www.borisfx.com/sony/bccsvp/Graphics-Cards.php
If your system meets the min specs for OGL then you might want to put a call into our support dept and one of our tech support folks would be happy to work with you on resolving the problem.
Cheers,
Peter.
Chris Marquart
on Oct 16, 2012 at 1:47:25 am
Peter,
Thanks for the info, after much searching, you can add me to the list of people who need to change Vegas 11 to "Window 7 Compatibility Mode" Just finished rendering my project without a problem after doing that.
Have a good week.
Chris
