Final Cut Pro 7 can't load and says "quit unexpectedly while using the Boris Continuum Shaders Plug-in"
COW Forums : Boris FX
Mark Pope
on Sep 21, 2012 at 4:02:04 am
Final Cut Pro 7.0.3 can't load and says "quit unexpectedly while using the Boris Continuum Shaders Plug-in"
Using iMac late 2009 with 10.8.1 Mac OS
I haven't used FCP in a month or so and can't remember what other software I have added in the meantime. I think it was Mocha Pro3 and Red Giant Trapcode Suite for After Effects. Maybe some free effects for AE too, not sure. Haven't been using lately. Shouldn't matter, but using After Effects 10.0.2.4
Process: Final Cut Pro [23622]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [337]
User ID: 501
PlugIn Path: /Library/Plug-Ins/*/Boris Continuum Shaders
PlugIn Identifier: com.BorisFX.BorisContinuumShaders
PlugIn Version: 7.0.2 (7.0.2)
Date/Time: 2012-09-20 20:50:56.294 -0700
OS Version: Mac OS X 10.8.1 (12B19)
peter mcauley
Re: Final Cut Pro 7 can't load and says "quit unexpectedly while using the Boris Continuum Shaders Plug-in"
on Sep 21, 2012 at 1:45:29 pm
Hi Mark,
Have you tried reinstalling Boris Continuum? If this doesn't help, I'd suggest contacting our support group. You can reach them via email at support@borisfx.com.
Cheers,
Peter.
