RED5 filters to color/light correction...
COW Forums : Boris FX
Carlos Silva
on Aug 10, 2012 at 6:54:44 pm
I am trying to begging in the right way with my Vegas11 + RED5 workflow.
About video, in most of my footage (interviews around 2 hours length) I need to deal with light variation. Sometimes it begins darker and ends lighter (and vice versa). There is a short sample here, without any treatment=> http://my.cloudme.com/carloscadu/timelapse.
Through Vegas I would use "color corrector" + "color curves" to deal with. Would RED5 provide any filter that could deal with in a better way than these Vegas tools?
Thanks in advance,
Cadu
peter mcauley
Re: RED5 filters to color/light correction...
on Aug 13, 2012 at 11:56:00 am
Hi Carlos,
For that, I'd suggest using the BCC 3 Way Color Grade filter in Boris RED. No automation but you can keyframe the exposure control to handle the light variation. Use the info window to get precise measurement of the light adjustment while you the grade the shot.
Cheers,
Peter.
Carlos Silva
on Aug 13, 2012 at 2:55:41 pm
Thanks for information Peter!
Just to clarify, could I deal with some contrast adjustment by using BCC 3 Way Color Grade, or to that should I use another filter?
Cheers,
Carlos
peter mcauley
on Aug 13, 2012 at 3:43:09 pm
Hi Carlos,
Yes, you can use the 3 Way Color Grade in RED 5 to take care of that - remember, you'll need to keyframe the parameter of choice (perhaps exposure) to even out the lighting in the shot. You might want to try the BCC Flicker Fixer too just to see if this can solve the problem without the need for keyframing.
Cheers,
Peter.
Carlos Silva
on Aug 13, 2012 at 4:17:02 pm
Hi Peter,
It seems BCC Flicker Fixer isn't available at RED5 bundle, is it?
So far I couldn't find that...
Carlos
peter mcauley
on Aug 13, 2012 at 5:00:24 pm
Hi Carlos,
You are correct - RED 5 does not include BCC Flicker Fixer, however, you can download the trial installer for BCC and give that a shot.
Cheers,
Peter.
Carlos Silva
on Aug 13, 2012 at 5:20:50 pm
Hi Peter,
Thanks for information again!
I am investing on RED5 bearing in mind it is the most balanced featured product from Boris. Am I right about that?
Otherwise, BCC seems to provide great tools as well.
Also, it seems there are much overlap of RED5 and BCC features. Do you know what would be the basic differences between RED5 and BCC?
Cheers,
Carlos
peter mcauley
on Aug 13, 2012 at 5:48:24 pm
Hi Carlos,
Perhaps this might help:
http://borisfx.cachefly.net/borisfx/download_files/2011BrochureWeb.pdf
http://www.borisfx.com/products/matrix.php
Cheers,
Peter.
Carlos Silva
on Aug 13, 2012 at 6:24:10 pm
Thanks for information!
It is all I need to clarify the product features.
Bye,
Carlos
