Boris red 5 - Vegas pro 11 - Eon Fusion 6
COW Forums : Boris FX
Guenal Jean-Luc
on Jun 7, 2012 at 3:47:18 pm
Hello from France,
I install Boris Red 5.1.5 trial in Vegas Pro. it works.
But my Eon Fusion 6 can not be run, since the installation of Boris Red.
Do you know this problem ?
thank you
Boris Yamnitsky
Re: Boris red 5 - Vegas pro 11 - Eon Fusion 6
on Jun 7, 2012 at 4:44:09 pm
We've not seen this problem but then, we do not run Vegas and Fusion on the same machine. I'll have our support team investigate your problem.
Boris Yamnitsky
BorisFX
Guenal Jean-Luc
on Jun 7, 2012 at 5:35:17 pm
Thank you so much Boris,
I seem to recall that BCC7 Trial posed the same problem because OFX settled in Common files... but I'am not sure.
Jean-Luc
Jeremy Ellis
on Jun 7, 2012 at 6:09:19 pm
Jean-Luc,
You are correct and that is most likely the issue. The Red installer defaults to installing to:
C:/Program Files/CommonFiles/OFX/Plugins
If you uninstall and reinstall and change that to:
C:/Program Files/Sony/Vegas Pro 10.0/OFX Video Plugins
that should correct the problem. Please let me know if that works.
Thank You
Jeremy
Boris Support
Guenal Jean-Luc
on Jun 7, 2012 at 10:17:14 pm
Jeremy,
I installed in C :/ Program Files / Sony / Vegas Pro 11.0/OFX Video Plugins.
But I found a file in: Program / ​​OFX / Plugins / BorisRed.ofx.bundle / contents / Win 64/BorisRED.ofx
Eyeon Fusion displays that can not start because of this.
Is it possible to move "BorisRed.ofx" ?
Jean-Luc
Jeremy Ellis
on Jun 8, 2012 at 2:44:54 pm
If that file is in the Common Files folder than yes you would want to remove that and only have it in the Sony specific folder.
Thank You
Jeremy
Boris Support
Guenal Jean-Luc
on Jun 12, 2012 at 5:10:15 pm
Jeremy,
I moved the folder in : Vegas Pro Video 11.0 / OFX Plugins / BorisRed.ofx.bundle / contents / Win 64/BorisRED.ofx.
Boris Red and Vegas Pro 11 work.
But Eyeon Fusion does not start.
