BCC Effects causing Media Composer error message
COW Forums : Boris FX
Stuart Pollock
on May 14, 2012 at 2:58:24 pm
Hello:
Using Boris FX (BCC AVX 6.0.6)in AVID Media Composer 5.5.3; Windows XP
Suddenly (in the middle of a project), in MEDIA COMPOSER 5.5.3, whenever I place a BCC FX on the time-line I am receiving the following error message: "Exception. A serious error has occurred. It is recommended that you restart the application immediately". Of course, editing is then impossible. Happily, I'm able to do some tasks though, including "Undo", which I perform. The error message then disappears and MC behaves normally again -- no restart seems to be required. Oddly, Boris AVID FX files work fine.
Obviously something wonky has happened to my BCC Effects. Any ideas about how to restore them to use? I have the original installation disc that came with the boxed MC (but 4.0) so a BCC FX uninstall/reinstall is possible. If that's necessary, what's the "safe" proceedure? Thoughts?
Jon Kozenko
Re: BCC Effects causing Media Composer error message
on May 14, 2012 at 10:15:20 pm
Stuart,
I actually just sent you an email from Boris FX Technical Support. If you have not yet received this email, let me know. Primarily I recommend an Uninstall/Reinstall/update, but there are a few additional things I go into detail with.
Thanks.
Stuart Pollock
on Jul 24, 2012 at 1:49:49 am
It has been two months --- no solution. A Boris tech-support "agent" directed me to download/install the latest version....then when that didn't resolve the issue, he passed me off to another department(which I've not heard from). Any ideas what to do?
Regards,
Stuart
