Premiere / BCC Tracker / Can´t clear cache
COW Forums : Boris FX
Sabri Liefert
on May 11, 2012 at 5:35:09 pm
Hello,
i want to reset/clear a tracker.
There is a screen showing "To clear the cache, slightly
change an unused parameter in the effect."
But i changed parameters and pressed reset several times. The message doesn´t disapear.
Premiere CS5.5 / BCC Cont. 8.0.2
(btw: this is driving me crazy)
Jeremy Ellis
Re: Premiere / BCC Tracker / Can´t clear cache
on May 14, 2012 at 8:45:01 pm
Hello,
You are correct that this should not be happening. What effect are you using when you see this? Are you moving the playhead to the first frame when trying to clear the cache? Please feel free to email me directly at jeremy@borisfx.com
Thank You
Jeremy
Boris Support
