Latest Update for Boris RED Killed Boris
COW Forums : Boris FX
Ken Bennett
on Mar 29, 2012 at 3:22:07 am
I just downloaded the latest update for my Boris FX RED. The update required me to re-register. After that Boris doesn't even launch. Dead. Nothing. So much for updates.
So, is the latest update no good at all?
Ken Bennett
Video Adventures
Capturing Your Life's Adventures!
peter mcauley
Re: Latest Update for Boris RED Killed Boris
on Mar 29, 2012 at 1:58:47 pm
Hi Ken,
We have had no other reports like this but I'm sure we can help solve the problem.
Please reach out to our support guys asap ... they'll sort this out for you either over the phone or via email, whichever is most convenient for you.
888 772 6747
support@borisfx.com
Cheers,
Peter.
Ken Bennett
on Mar 29, 2012 at 5:13:27 pm
I called support and now they want me to send in provide proof of purchase before they can even help me.
I uninstalled and reinstalled and it does launch but now says my serial # is invalid. And it's the same number in my Boris online account which "they" can't accept as me actually owning it.
Ken Bennett
Video Adventures
peter mcauley
on Mar 29, 2012 at 5:23:31 pm
Hi Ken,
If you bought the product then we must have a record of the purchase. Did you purchase using the same name that you are using in this forum?
Peter.
Jaeson Koszarsky
on Mar 29, 2012 at 5:39:14 pm
Does the latest RED update support Media100? M100 isn't listed in the RED5.1.3 download options.
Jaeson
peter mcauley
on Mar 29, 2012 at 6:52:15 pm
Yep ... you need the 32 bit version of RED 5 though.
Cheers,
Peter.
peter mcauley
on Mar 29, 2012 at 6:46:20 pm
Hi Ken,
Thanks for sending in your proof of purchase ... seems like you should be all set now.
Cheers,
Peter.
Ken Bennett
on Mar 30, 2012 at 4:18:04 pm
Seems I now have Boris RED installed but it's not showing up in Vegas Pro 10e. How do I get it to show up?
Ken Bennett
Video Adventures
peter mcauley
on Mar 30, 2012 at 4:26:50 pm
It should show up after the installation ... did you use the correct installer for that host? I ask because Vegas is offered in both 32 and 64 bit versions and you'll need to use the corresponding RED 5 installer in order for the plugins to be seen by the host.
If you are sure that you've used the correct installer for that host version, then you should get in touch with our support guys. They can help you resolve the issue in short order. You can reach them via phone or email here:
888 772 6747
support@borisfx.com
Cheers,
Peter.
