boris red 5.1.3 and vegas pro 11 - PAL
COW Forums : Boris FX
Wilfried Van
on Mar 15, 2012 at 6:17:03 am
Finally red recognises the 1440x1080 vegas footage right .
3 second m2t file -> apply boris red as plug-in of vegas
press play in red -> after going once through the 3 sec clip , boris red plays the clip at too high frame rate ( double frame rate ? )
( ram preview -> right frame rate )
go into project settings and cross manual setting , put HDV 1440x1080 25 ( although red knows it is custom 1440x1080 25 and shows as such )-> plays at right frame rate
return to vegas ( with cancel in red ) and go back into red -> plays again at too high frame rate -> project settings and uncross manual settings -> plays right frame rate .
Each time red is launched as plug-in of vegas , have to go to project settings in red and cross ( or uncross when crossed )and kind of re-confirm it is 1440x1080 25 , otherwise is plays the clip at too high ( double ? ) frame rate. ( ram preview is always at right frame rate )
Bizar
peter mcauley
Re: boris red 5.1.3 and vegas pro 11 - PAL
on Mar 15, 2012 at 1:25:51 pm
Hi Wilfried,
Thanks for reporting this - we'll try to reproduce it in our labs and if we can reproduce it here then there's a good chance that we can fix it.
Peter.
Wilfried Van
on Mar 15, 2012 at 2:51:24 pm
Thanks Peter ,
Hopefully we once get the basics working for PAL HDV and PAL DV ( when old material needs updating )
Wilfried
Wilfried Van
on Apr 4, 2012 at 7:57:11 am
Hi Peter ,
Were your labs able to look into this and if so , could you reproduce it and if so , is there to be expected a remedy ?
Best regards
Wilfried Van
on Jul 5, 2012 at 1:12:31 pm
RED whatever 5 version still playing PAL clip much too fast when RED being used as plug-in of vegas . ( as described here below or above )
Gave up on this BORIS RED( how long is version 5 now released ?? ) and bought the adobe production premium CS6 suite instead at a good price .
