RED5 plugin - hang
COW Forums : Boris FX
Guillaume Jeffrey
RED5 plugin - hang
on Feb 27, 2012 at 1:37:25 am
When I do the following, RED5 hangs when I hit "launch UI".
1- Apply RED5 as a videoFX on the event - making a Extruded text.
2- Hit apply and go back to Vegas timeline.
3- Add a transition on the same event
4- Use RED5 as transition.
5- Hit "launch UI"
Then RED5 opens but there is blank screen, and the program hangs. I need to kill Vegas process to be
able to conginue.
Can anybody reproduce this?
Jeppe Svendsen
Re: RED5 plugin - hang
on Feb 27, 2012 at 6:57:25 am
I had just the same experience with Media Composer and Avid FX (aka Boris Red) yesterday. I opened my preferences dialog and reset all settings to factory settings. Problem solved.
Maybe it will help you?
Jeppe
Boris Yamnitsky
on Feb 27, 2012 at 10:38:05 am
We've seen the sam problem in our QA labs and we are working with Sony team on a solution. In the meantime, avoid using Boris RED as a filter and as a transition on the same clip. Sorry for inconvenience.
Boris Yamnitsky
BorisFX
Guillaume Jeffrey
on Feb 28, 2012 at 2:36:47 am
Hi Boris,
Thanks for your answer.
I hope you can find a solution soon.
Guillaume Jeffrey
on Feb 29, 2012 at 4:22:40 am
Just notice that this only happens when an OpenGL filter is applied as effect whithin RED.
When no openGL effect, transition and effect can be applied on the same event w/o issue.
