RED5 plugin - rendering to different output
COW Forums : Boris FX
Guillaume Jeffrey
on Feb 25, 2012 at 7:40:39 am
I'm using Vegas with RED5. My source footage is 1080-50i and the project properties match the source.
I have created a custom transition with RED which I save as a preset in Vegas. This transition is using lens flare in the middle of screen then a text appears (still in the middle), then fade out.
So here is the problem I have: I need to render to 2 different format (the 1st is 720p, the 2nd is DVD PAL). When I render to 720p everything is fine but when I render to DVD the lens flare is distorted and the text is not centered anymore on the screen.
Is there a way to have the same output in both case?
