boris transfer from FCP 7 to AVID MC6
COW Forums : Boris FX
dan luke
on Feb 22, 2012 at 7:13:21 pm
I have a simple project, cuts only from quicktime files shot on 720p 23.976 tape encoded as HDV. I can import the sequences into avid and the clips show up but I can't do an ama relink even though I can load the original clips into the project using ama.
I am exporting one of the files as a pro-res 422 hq file to see if that makes a difference.
dan luke
Re: boris transfer from FCP 7 to AVID MC6
on Feb 22, 2012 at 7:30:02 pm
pro-res hq didn't help. Interesting note, when the clips are imported into MC6 the durations are much longer than the actual clip length.
peter mcauley
on Feb 22, 2012 at 7:40:29 pm
Hi Dan,
You should reach out to our support guys ... they'll help you with this. 888 772 6747 or support@borisfx.com.
Cheers,
Peter.
