SD Rendering From HD Project
COW Forums : Boris FX
Terry Grider
on Feb 18, 2012 at 2:39:47 am
I have an HD project that is 1920x1080 with Boris Red Transition Effects in the timeline. When I export the project in HD, the effects render correctly. When I export to SD 720X480, the effects look as though they are not scaled to the SD resolution. Is this a project setting in Boris Red that is wrong?
Terry
peter mcauley
Re: SD Rendering From HD Project
on Feb 21, 2012 at 1:09:41 pm
Where are you setting the render size? Are you scaling on the host output or changing the host project settings? What host are you using?
Peter.
Terry Grider
on Feb 21, 2012 at 3:06:37 pm
Hi Peter,
My Host is Premiere CS5.5. I have found that if I export directly from Premiere instead of queuing to Media Encoder, it works as expected. I don't know if it's an Adobe problem or something missing in the metadate sent to Media Encoder. Anyone else able to duplicate this scenario?
Terry
