RED5 - optical flow and optical stabilizer
COW Forums : Boris FX
Guillaume Jeffrey
on Feb 17, 2012 at 2:18:24 am
I need to stabilize and speed up some footage.
To get the best result, do I need to apply optical flow FX first?
What is the best workflow?
peter mcauley
Re: RED5 - optical flow and optical stabilizer
on Feb 17, 2012 at 12:15:16 pm
If you are just speeding it up, I'd suggest trying the BCC Velocity Remap filter. If you were slowing it down then I'd suggest using the BCC Optical Flow.
Cheers,
Peter.
Guillaume Jeffrey
on Feb 18, 2012 at 1:31:14 am
Hi Peter,
Thanks for the tip.
When I use velocity remap and motion stabilizer together, which one should I apply first on the clip?
