Boris Title 3d not updating
COW Forums : Boris FX
Nate Stephens
on Feb 13, 2012 at 2:57:40 pm
Ever since I moved to HD my Boris Title 3d in FCP is not updating in the timeline and other funky actions.
Right now in the controls tab I can get it to scale fonts but the leading control sticks and locks on the mouse, so were ever I move the mouse you can see the numbers in the leading parameters move.
If I change the font size some, the fonts look right in controls but on the time line they have not changed at all..
Yuk, This is not the Boris that I respected in the SD world... what happened
FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
Write for the Edit, Shoot for the Edit, Edit.....KISS Principle
peter mcauley
Re: Boris Title 3d not updating
on Feb 13, 2012 at 4:09:59 pm
Hi Nate,
This sounds very unusual ... is the UI update issue that you are seeing only apparent when using the Boris Title 3D product? Perhaps something else changed on the system which may be the root cause of the symptoms that you are reporting as it seems very odd to me that the system would exhibit this type of behavior by changing only the size of the project. Would you be open to working with one of our support guys to see if they can help you figure this out?
Please feel free to reach out to them by sending an email to support@borisfx.com. One of out tech support guys would be happy to help you with this.
Cheers,
Peter.
Nate Stephens
on Feb 13, 2012 at 4:43:03 pm
Thanks Peter for your reply.
I have had odd Boris problems off and on for a couple years.
I would love to find the problem.
Will email tech support
