RED 5 for Media Composer 6 Timeline? Also BCC8 updates?
COW Forums : Boris FX
Quincy Barker
on Jan 30, 2012 at 2:11:38 pm
My studio took the plunge into Media Composer 6 after confirming that Avid FX could read RED 5 project files. I have run into a few issues, though.
1. Avid FX can't read RED 5 plugins on the timeline, so no changes or updates can be made unless there is a saved project file outside the Avid. So a RED 5 update is necessary.
2. No imported .mov files or audio files work in AVID FX. So the limit of video tracks is stuck at 6 and must be read from the Avid timeline. Image sequences are a workaround, but hardly as good an option. Using audio is a big help when doing sophisticated projects. I understand this could take time to implement due to Win 64 issues. Will it happen?
Also, wondering about the coming BCC8 plugins for AVX. Really looking forward to the new stuff!
Boris, love the products immensely, they make our productions so much better. I'd just love some sort of timeline on when and if these things will come.
mike meyerson
Re: RED 5 for Media Composer 6 Timeline? Also BCC8 updates?
on Jan 30, 2012 at 7:14:02 pm
Are they NOT available already??? They are on the Boris site, but I didn't actually look into whether or not they are specifically for avid.
Can anyone tell me if the new 64bit versions of RED and BCC will be able to open FX created w/ previous versions (in the avid timeline)???
I'm looking forward to making the jump to MC6 as well. I have a lot of old projects that need to get updated from time-to-time....and a lot of titles/graphics created w/ RED4 (and older) as well as older versions of BCC. It would really be shooting myself in the foot if all those old FX couldn't be used w/ the newer versions.
thanks
Quincy Barker
on Jan 30, 2012 at 7:23:01 pm
Yes, BCC8 will open any prior instances within Media Composer timeline. RED 5 should as well, but has yet to be updated to work within MC6 & it's 64bit architecture - so no updating those files yet.
mike meyerson
on Jan 30, 2012 at 7:53:34 pm
Thanks Quincy.
When I updated to RED 4, I had to keep version 3 installed to open any old FX...I'm guessing I wont be able to install any older versions of RED into MC6 due to the jump to 64bit...so hopefully it'll work. I guess I'll have to hold off and see.
Boris Yamnitsky
on Jan 30, 2012 at 8:02:35 pm
I'll try to answer all questions in one post:
- old Avid timelines with Avid FX should open fine with MC6 - AvidFX 6 combo, let us know if you see something strange
- Avid timelines with RED 4 effects will not immediately open in Avid FX 6. We are working on a compatibility solution.
- BCC 8 AVX is available for MC 6 - 64 bit now! Older Avids will be supported in near future.
Boris Yamnitsky
BorisFX
Quincy Barker
on Jan 30, 2012 at 8:23:41 pm
Thanks Boris,
Any news about RED 5 for MC6?
mike meyerson
on Jan 30, 2012 at 8:35:59 pm
THANKS BORIS!
Wojciech Baredziak
on Jan 31, 2012 at 7:58:57 pm
AvidFx6 doesn't work correctly with MC6. A lot of transitions gives diffuse images for incoming/outgoing clips. Some filters gives the same effect :-( I've tested it for about two days. My friend has the same problem.
I asked a few times at the Avid's forums when Red 5 will be aviaiable for MC6, but never get any answer.
Boris Yamnitsky
on Jan 31, 2012 at 8:24:30 pm
If you are on the Mac, make sure to run AvidFX 6.03 available as free download from our website:
http://www.borisfx.com/updates/#null
if you are on windows, wait for a couple of days until we post the windows version.
RED 5 for Avid is in the works too.
Boris Yamnitsky
BorisFX
Wojciech Baredziak
on Jan 31, 2012 at 8:30:22 pm
I'm on the PC, so must wait.
Thank you for your fast answer. It is the first message from Boris I get.
Hope that AvidFx6 update and Red 5 will be sooner than later.
All the best .
Boris Yamnitsky
on Feb 1, 2012 at 2:32:20 pm
We posted AvidFX 6.03 for MC6, 64 bit, windows platform. All windows AvidFX users are encouraged to download a free update:
Boris Yamnitsky
BorisFX
Wojciech Baredziak
on Feb 1, 2012 at 2:44:59 pm
The fastest reaction I've ever seen - update without 12 hours ;-)
Just downloaded ...
peter mcauley
on Jan 31, 2012 at 10:03:14 pm
I think I understand what the problem is. Can you try something for us?
Please launch AvidFX 6 / RED 5 and go to Edit>Preferences ... this will open the preferences window. Then in the preferences window, select the Preview tab and disable the "Render In Draft Mode" feature by unchecking the box. Then click the OK button and go back to the main Avid FX / RED interface. Then make sure to set the Comp window to Full, instead of Draft.
Please let me know if this solves the problem that you are seeing with the diffuse color.
Peter.
peter mcauley
on Jan 31, 2012 at 10:21:02 pm
Also, and just for the sake of clarity, do you think you might be able to send us some images that show us exactly what the problem looks like on your system?
Peter.
Wojciech Baredziak
on Jan 31, 2012 at 11:06:14 pm
My screenshots:
http://imageshack.us/photo/my-images/705/poorquality.png/
http://imageshack.us/photo/my-images/46/goodquality.png/
Wojciech Baredziak
on Jan 31, 2012 at 10:40:28 pm
Preferences/Settings were the first place when I looked, but ... I'm at the front of my system and:
-composition window - preview quality: high
-composition window - preview resolution: full
- render in draft mode - unchecked
Transition quality is poor ... soft images, looks like in draft mode - sorry.
I try preset: Library >Transitions/DVE Transitions/Wipes/QuadBar DVE
It is interesting, that not all presets are poor ! Some looks perfect.
I use only presets for my tests.
peter mcauley
on Feb 1, 2012 at 2:43:04 pm
Okay - I think I have figured it out.
• Load the preset that you were using (QuadBar DVE Wipe)
• Select Track 1
• Go to the Composite Tab in the Controls Window
• Scroll down and observe that there is a parameter labelled Horizontal
• Remove any keyframes for this parameter and set the value to 0 (or you can achieve the same thing by setting the keyframe interpolation for this parameter to Constant and setting the value to 0)
Do the same thing for the other track.
Please let me know if this produces the result that you have in mind.
Cheers,
Peter.
Wojciech Baredziak
on Feb 1, 2012 at 2:47:05 pm
Thank you Peter - I'll try it with 6.0.3 update and report here ...
Wojciech Baredziak
on Feb 1, 2012 at 4:35:17 pm
A BIG RESPECT for you Peter !
I'm not new in Red, but looks like I was blind for the last two-three days.
Problem solved and all works fine, now.
Thank you for your assistance and time.
All the best.
peter mcauley
on Feb 1, 2012 at 4:41:44 pm
Delighted to hear that helped solve the problem - thanks for letting me know that you're all set - and for the kudos.
Cheers,
Peter.
Wojciech Baredziak
on Feb 2, 2012 at 9:48:26 am
I have tested more presets. It looks like new version has some problem to open correctly "older" presets. Very often horizontal and/or vertical parameter is set to 15 - 16 value.
Mike Meyerson
on Feb 27, 2012 at 3:02:29 pm
any updates on Red for MC6?
