Motion Tracking?
COW Forums : Boris FX
Bastian Krüger
Motion Tracking?
on Jan 14, 2012 at 1:00:19 pm
(using MC 5.0)
Does anybody know, how to link an effect (for example a lightning effect) to a motion tracker. Some effects (for example BBC lightning) doensn't have a possibility of motion tracking inside.
I found a solution with the BBC Match Move effect. This effect affects to the track below. Therefore, after applying the BBC lightning to the videotrack and applying BBC Match Move to a neutral filler above, I have to change these two tracks. After that, I open the effect pallette and set "MM Foreground" to "First Below".
Now, everything is simply good tracked, and it works. BUT: the tracked item (in that example the BCC lighting) is just to see on a black window (frame size).
Does anybody know, where the error is?
Thanks...
