BCC7 Where to find current installed version number
COW Forums : Boris FX
Merlin Leach
on Dec 30, 2011 at 4:20:10 pm
My BCC7 Account has the original Sn and version listed. When I upgrade to a newer version (Fm 7.0.3xx to 7.0.4.xxx) is doesn't change. Looked under "about" on plugins and only shows ver 7.
Where can I locate the current version # I have installed. Just realized I upgraded twice the same version.
Jeremy Ellis
Re: BCC7 Where to find current installed version number
on Dec 30, 2011 at 5:29:16 pm
On Windows machine the best way is to go to the "Control Panel" and then go to "Uninstall Programs" This will list all programs installed on your system and the far right column will show you the exact version number for each product.
Thank You
Jeremy
Boris Support
Merlin Leach
on Dec 30, 2011 at 5:41:33 pm
Thank you. I have Vista 32 bit and Vegas Pro 11. Anyway when I go there it gives me BCC7 OFX 32bit, Publisher, then date installed. No version. What do I need to do to display further. Nothing exists to the right.
