RED 5 Wire Remover -- Multiple filters cancelled out by the filter on the uppermost track
COW Forums : Boris FX
Carl Alessi
on Dec 12, 2011 at 5:09:38 pm
I'm using RED 5 in conjunction with Sony Vegas 11. I've applied RED as an event effect to a clip, with the intention of elminating five power lines that are visible in the corner of the frame.
Applying a single filter in RED was easy, and worked perfectly. Following directions, I tried applying a second filter to eliminate the second wire. Unfortunately, I'm finding out that no matter what I do, the filter that occupies the uppermost track always cancels out any wire remover filters I have in lower tracks--those wires simply reappear in the frame.
Can anyone suggest a way out of this?
Thanks in advance,
Carl
Boris Yamnitsky
Re: RED 5 Wire Remover -- Multiple filters cancelled out by the filter on the uppermost track
on Dec 13, 2011 at 12:33:47 pm
Can't say for sure what the problem may be, but we'll try to investigate in our support lab and report back to you.
Boris Yamnitsky
BorisFX
