problem with bcc motion key
COW Forums : Boris FX
james stratton
on Nov 29, 2011 at 2:43:53 pm
hi
i am using this method
http://library.creativecow.net/articles/mcauliffe_kevin/motion_key/video-tu...
to remove a figure from my shot
everthing works fine but when i play back the shot with the figure removed i can see a faint vertical band moving acros the screen where the figure was
does anyone know why this could be
thanks
peter mcauley
Re: problem with bcc motion key
on Nov 29, 2011 at 4:43:27 pm
There could be several reasons for this, such as:
• mask not big enough to cover the moving object in every frame
• replacement range not long enough / too long
• feathering too big
• luma comp set too low / too high
I think your options are either:
• adjust the aforementioned settings until you achieve the desired result
or:
• render the result that you have an re-run the motion key on the rendered result to eliminate the vertical image artifacts.
I hope this helps.
Peter.
james stratton
on Nov 29, 2011 at 5:24:13 pm
that was helpfull thanks
it not quite right yet
but the figure was very close up and big
so i guess that might be making it hard work
