RED transition problem
COW Forums : Boris FX
Sivan Geyra
on Oct 28, 2011 at 2:13:34 pm
I posted this problem at another part of the forum but i might find a better answer here...
I have a problem with transitional effects while authoring Blu Rays.
Here is my work flow:
Final Cut Pro 7
BORID Red Plugin (for the effects)
EXPORT SETTINGS: Quicktime Movie - Self Contained
AUTHORING TOOL: Toast Titanium 11
Mpeg4 AVC
Bit Rate: 8-16 mbps
Motion est: Best, Half PEL
rest is auto.
when I play the Blu Ray all of the transitional effects are unsmooth and laggy.
Any Suggestions?
peter mcauley
Re: RED transition problem
on Oct 28, 2011 at 6:33:19 pm
I'm not 100 percent sure of what the cause of this problem may be, but I have a few things to offer for suggestions, some of which you may have already tried but it's worth a shot.
• make sure to set the RED transitions / effects to full quality and full resolution before rendering
• make sure that the timeline is rendered fully and plays back smoothly before going to DVD
• if you are using apple compressor this might be related to the issue - try doing it bypassing compressor
• disable opengl setting in RED
I hope one of these suggestions helps.
© 2018 All Rights Reserved
