Boris red
COW Forums : Boris FX
Bart Molen
Boris red
on Sep 19, 2011 at 12:37:37 am
Hello
I'm using Boris Graffiti with Corel VideoStudio, would like to know if I could also use Boris red. If its not possible can Boris Red be used as stand alone?
Jon Kozenko
Re: Boris red
on Sep 19, 2011 at 10:01:35 pm
Bart,
Unfortunately, RED will not work directly with Corel VideoStudio, but yes, RED can be used as a stand-alone program (in RED's case it's called the 'Engine'). You can use RED stand-alone to import/export media between itself and Corel. I would recommend downloading the trial version to see how the import/export workflow works for you - the trial does not have any import/export limitations, so you can run full tests with the trial version.
Bart Molen
Re: Boris red
on Sep 19, 2011 at 11:30:27 pm
Thanks for the reply, will try the trail version first.
