Unable to load EPS into Red
COW Forums : Boris FX
William Miller
on Aug 22, 2011 at 3:25:01 pm
Hi, I've been using Red for many years and have not run into this before. I am using Red 4.3 and I am trying to use an Illustrator file that I was given of the company's logo. When I open it in Illustrator the file has only one layer and is a RGB file. I have saved it as an Illustrator 9 and 10 and using as it was given me (I don't know which version it was created in). It doesn't show up in Red when I import it as the native file. I get an error that Red can not read the versions 9 & 10. Any ideas?
Jon Miller
404-216-6021
wjonm2002@yahoo.com
http://jonmiller.tv
Boris Yamnitsky
Re: Unable to load EPS into Red
on Aug 26, 2011 at 12:49:39 pm
try to save it as Illustrator 8. Also, if the file only had RGB data (meaning raster image data) you will not be able to access splines in RED. However, you may be able to convert to splines by using our Vector Trace feature.
To learn more about vector trace watch this tutorial:
http://www.borisfx.com/videos/RED/3D-Extruded-Logo.php
Boris Yamnitsky
BorisFX
William Miller
on Aug 26, 2011 at 1:04:36 pm
Thanks Boris, I'll try your suggestions.
Jon Miller
404-216-6021
wjonm2002@yahoo.com
http://jonmiller.tv
