Avid 5.5.1 and BCC 7.02 authorisation issue
COW Forums : Boris FX
Rob Clark
on Apr 26, 2011 at 7:07:41 am
I am getting an error on startup of avid 5.5.1 on a vista machine with BCC 7.02. The error comes up several times and says:
Unable to verify authorization. Please install BCC from its original distribution CD-ROM
I have to click this screen off several times before I can access avid. After that avid appears to work with BCC.
I have contacted BCC support and reloaded a new install and new serial number with BCC. But same issue.
Anyone have any ideas?
Rob
peter mcauley
Re: Avid 5.5.1 and BCC 7.02 authorisation issue
on Apr 26, 2011 at 5:49:40 pm
Hi Rob,
So did you actually speak to anyone in support? If not then I'd suggest giving them a call as I'm sure they can help with this.
You can reach them by phone at 1 888 772 6747 or via email at support@borisfx.com.
Cheers,
Peter.
Rob Clark
on Apr 27, 2011 at 3:16:54 am
Thanks Peter.
No only by email, but I have fixed the issue. I had two earlier versions installed BCC 4.2.2 and 6. One of them was causing a conflict. More than likely BCC 4. Removed them both and it worked.
Thanks for your response
Rob
