jittery zoom and pan in shot
COW Forums : Boris FX
Trace Pratten
on Mar 24, 2011 at 5:47:10 am
Hello. I have some footage that when the pan and zooms starts toward the subject it is a bit jittery. What would be the best filter? Since I have the Cont. 7 series, I have a choice.
I thought just going to the camera stabilizer but was not sure if something in the pan and zoom filter would be better since I may have more control over the entire shot?
Thank you.
peter mcauley
Re: jittery zoom and pan in shot
on Mar 24, 2011 at 1:20:19 pm
I'd suggest adding the BCC Optical Stabilizer to the shot to eliminate the unwanted movement in the shot. If you need assistance on use of the filter, just drag it onto the clip and then click on the help button, which will open up the pdf help file that explains how to use the filter in many different host environments.
I hope this helps.
Cheers,
Peter.
