Apply Motion track to text in BCC7
COW Forums : Boris FX
Wade Harrington
on Nov 29, 2010 at 5:57:23 pm
Is it possible to motion track an object and then apply the motion path to a text in Vegas Pro 10 with BCC 7? I want the text to follow the object on screen and maybe even add a little 3d effect also.
peter mcauley
Re: Apply Motion track to text in BCC7
on Dec 3, 2010 at 2:44:09 pm
Hi Wade,
Currently this is not possible in BCC, however, you can achieve this effect is you use Boris RED. You can use RED to tracker an object in the scene and then apply the motion data to any object, which in your case would be a 3D text element.
You can download the free trial of RED here:
borisfx.com/downloads
I hope this helps!
Cheers,
Peter.
