Boris Continuum Complete 7.04 and Extruded EPS filter
COW Forums : Boris FX
Pero Peric
on Oct 2, 2010 at 6:47:21 pm
So, I have EPS picture which is correct:
http://i157.photobucket.com/albums/t65/Warrior30/EPS1.jpg
If I apply Extruded EPS filter from BCC 7.04 in After Effects CS5, I get this image:
What am I doing wrong? Is it bug in Boris Continuum?
Thanks.
Pero Peric
Re: Boris Continuum Complete 7.04 and Extruded EPS filter
on Oct 2, 2010 at 9:29:54 pm
Uuups, for picture 2 correct link should be:
http://i157.photobucket.com/albums/t65/Warrior30/EPS2.jpg
peter mcauley
on Oct 4, 2010 at 1:20:41 pm
The EPS file that you are attempting to extrude is rather complex and might require a slightly different workflow than a more standard EPS logo Illustrator file. To successfully generate the result you are expecting, I'd suggest that after you extrude the EPS file, you then disable the Keep EPS Color switch in the filter control panel and use the original illustrator file as a texture layer to map the original colors back onto the extruded result.
I hope this helps.
Cheers,
Peter.
