BCC Optical Stabilizer
COW Forums : Boris FX
Clay Elder
on Sep 5, 2010 at 5:56:53 am
Recently moved to Media Composer 4.0.5 Win / Mojo. Trying to use BCC6 effects like Optical Stabilizer and if the clip is several seconds long, BCC causes the program to force close. I also tried BCC Extruded Text and work flow is very slow or doesn't work.
Are there settings that could be wrong?
I edit on Xeon 3.4ghz with 2 gb ram , Quadro 1300FX card.
Thanks for any help.
peter mcauley
Re: BCC Optical Stabilizer
on Sep 7, 2010 at 1:49:19 pm
We approved BCC AVX on a similar set up as the one that you describe and I don't recall any issues with the Optical Stabilizer or the Extruded Text filters.
Have you considered trying the latest version of BCC AVX (which you can download from http://www.borisfx.com) to see if this eliminates the problems that you are seeing with your system?
Otherwise all I can suggest is that you please get in touch with one of our techs via email (support@borisfx.com) and they will assist you in troubleshooting the problem.
Cheers,
Peter.
Jeremy Ellis
on Sep 7, 2010 at 8:22:45 pm
Hello Clay, please contact me directly at jeremye@borisfx.com if you are still having an issue so we may troubleshoot.
Thank You
Jeremy
Boris Support
