 | Graffiti with Studio 12: How to hold the last frame of an animated title?
on Aug 30, 2010 at 10:49:24 am |
I'm trying to use the 'animated container' title, specifically the one called 'Squeezeon'.
What I want is to have the animated text appear on the screen, and hold the last frame of the animation there. I have tried extending the animation duration, but this only slows down the overall speed at which the letters appear on the screen.
Does anyone know how to hold the frame?
 | Re: Graffiti with Studio 12: How to hold the last frame of an animated title? on Aug 30, 2010 at 3:08:49 pm |
Try this:
• go to the frame where you want to hold the animation
• select the track labelled Text in the timeline
• in the Controls Window, click on the Type On tab to select it
• click on the square next to the Text Type On parameter to add a keyframe and select Hold from the list of available keyframe types
You can now set a new duration for the effect without affecting the animation.
Please let me know if this helps.
Cheers,
Peter.
