Connect BCC Zoom light to the movement of a spline
COW Forums : Boris FX
Theo van Laar
on Jun 26, 2010 at 7:27:33 am
I used Graffitti 5.3 to make a 3D extrusion of the map of Holland. Then I placed a BCC Light Zoom in the biggest lake.
When I animate the position and rotation of the 3D map, I would like that the BCC Zoom light follows this movement, so that this effect stays in the middle of the lake. However, what I try, the spline track and the BCC Zoom track are not connected. I even tried to plave them into a 3D container, but it still doesn't work.
What is the right way to connect the position of the BCC Zoom light to the position of the spline?
Theo
Matthew Mullen
Re: Connect BCC Zoom light to the movement of a spline
on Jun 28, 2010 at 6:39:00 pm
Theo,
I'm really not sure without looking at it.
If you send the media to my e-mail I'll gladly take a look.
-Matt M.
peter mcauley
on Jun 29, 2010 at 3:21:57 pm
The Light Zoom needs to be placed upstream of the transforms for it to move with the transformed map - try dragging the filter and the map into a container and then making all of the transform moves to the container and not the extruded map track.
I hope this helps.
Peter.
Theo van Laar
on Jul 1, 2010 at 10:22:45 pm
Theo
