error message
COW Forums : Boris FX
Dustin Ward
error message
on Jun 16, 2010 at 4:29:33 pm
I cannot import my XML into After Effects. I have done this before... I don't understand.
I got this message:
After Effects: AEGP Plugin Boris XML Transfer:
Cannot import this file with the Final Cut XML Importer.
Dustin Ward
Re: error message
on Jun 16, 2010 at 4:56:16 pm
apparently you have to right click and select "Final Cut XML via Boris XML Trnasfer". You can't just drag it in or use command I.
