opacity keframes backwards
COW Forums : Boris FX
Dustin Ward
on Mar 31, 2010 at 5:11:25 pm
I'm using Boris XML Transfer, but when transferred from FCP to AE, the cross dissolve works the wrong way. Instead of going from 0 to 100, it goes from 100 to 0.
Matthew Mullen
Re: opacity keframes backwards
on Mar 31, 2010 at 6:06:02 pm
What version of XML transfer are you using?
Dustin Ward
on Mar 31, 2010 at 8:30:22 pm
the latest
Matthew Mullen
on Mar 31, 2010 at 9:01:55 pm
Make sure your import settings are set to Layers 'Step Upwards'
If it is and you are still experiencing the issue could you send the XML to me . . . mattm@borisfx.com
Dustin Ward
on Mar 31, 2010 at 9:06:18 pm
just sent it
Matthew Mullen
on Apr 1, 2010 at 2:58:48 pm
Dustin,
We've taken a look at your XMl and it seems fine to us.
You have some cross dissolves at the beginning of clips and ones at the end of clips. Cross Dissolve would go from 0 to 100 for the beginning ones and from 100 to 0 at the ending ones. We can't find any instance here that is incorrect.
If this is wrong please clarify.
Dustin Ward
on Apr 1, 2010 at 3:24:29 pm
At 0:00:51:02 the opacity starts at 100% and then fades out as she begins talking. This is not correct. I ended up just exporting the clips that had a cross dissolve from FCP so that I could finish my work, but I would still like to know what the problem is so that I don't have to keep doing this in the future.
Matthew Mullen
on Apr 1, 2010 at 3:49:21 pm
We'll look at it again.
Matthew Mullen
on Apr 1, 2010 at 4:57:17 pm
Dustin,
Can we see a screen shot showing the opacity values.
We see 2 dissolves at this point.
One ending at the clip and one beginning at the cut for the next clip.
Both look as expected when we import the XML???
Also, did you make sure your import settings are set to Layers 'Step Upwards' ?
Dustin Ward
on Apr 1, 2010 at 6:07:21 pm
It seems that the ones that fad out are ok, just not the ones that fade in. Every crossfade that came from FCP became a fade out.
Matthew Mullen
on Apr 1, 2010 at 6:33:54 pm
Can I see a screen shot?
Dustin Ward
on Apr 1, 2010 at 6:11:59 pm
Matthew Mullen
on Apr 1, 2010 at 6:37:46 pm
Sorry,
Didn't see these screen grabs posted.
I'll let you know.
Matthew Mullen
on Apr 2, 2010 at 4:24:57 pm
The only thing that might explain the differences is you are not on the latest.
Can you double check the version by navigating to /Library/Application Support/Adobe/Common/Plug-ins/CS4/ and getting info on the XML transfer bundle.
Let me know what version it says.
-Matt
Dustin Ward
on Apr 2, 2010 at 5:06:53 pm
1.0.1.2
Matthew Mullen
on Apr 2, 2010 at 5:11:48 pm
The latest is 1.0.5, should resolve your problem.
Grab the update from our updates page:
http://borisfx.com/updates'>
Matthew Mullen
on Apr 7, 2010 at 7:09:13 pm
Dustin,
Just want to check in.
Did updating resolve your issue?
Dustin Ward
on Apr 7, 2010 at 7:13:11 pm
Thanks for checking. I haven't started another project yet that involves this issue, but it most likely fixed it because it was listed in the updates. I'll let you know next time I use it.
Matthew Mullen
on Apr 7, 2010 at 7:27:18 pm
OK, sounds good!
